Stingray74CC
It's been a while since I've surfed the webpages of the Corvette Action Center. I see alot of familar names. I'm glad to see that alot of you are better at sticking around than I am.
Anyhow, for the longest time, I've had problems with my tri-power setup. Vacuum leaks, plugs constantly fouled, no choke, gas leaks, stumbling on acceleration, backfire in the carb and exhaust so on and so on. So I've decided to change the intake and carb to an edlebrock setup...nothing fancy but hopefully make it run alot smoother and maybe even a little more power.
I went on Summit and ordered the parts that supposedly fit the car...intake happened to be a torquer II (the only one they sold that fits under a stock corvette hood). Well there was an issue, the intake ports on the heads are visible when I set the torquer II on the engine. I haven't done this type of work before on the car so I wasn't sure about the size when I ordered the part or even looked at it out of the box.
I did a little bit more internet searching and found a C427X that Edlebrock makes/used to make that will supposedly do the job.
Does anyone have any experience with this or have any recommendations on the parts I should use? BTW, the engine is an L89, 1969, 427.
Great to be back on the site.
Anthony
Anthony
