Marvyn741
New member
I just got a 96 Collector's Edition and it has an intermittent Service LTPWS light. I've heard from a couple places that by replacing some of the electronics that it might be possible to revive the sensor. I'm fairly handy with a soldering iron and I'd like to give it a try. If they're cheep enough and I even get one out of ten working then it would be worth it. I'm looking for sensors for the 93 through 96, the white case versions. My specific bad sensor is the Left Front - Green label but I've heard that the wheel location can be reprogrammed so any label color will do. Looking for ones that failed during use, not ones that were smashed by careless tire changers. I might try one that had it's band broken as long is it hasn't rattled around in the tire.
Marv Harris - Tampa
Marv Harris - Tampa
