M
mikejpss
gerryGerryLP said:Mike,
Do you happen to have an MSD Box connected to it? If the small red wire is not connected to a "switched" source, then it will tend to drain the battery. I believe that the light brown wire that connects to the distributor is the switch-connected wire in an L81 set-up.
Also, I have read about the courtesy light causing these issues here in the CAC site. Do a search under "battery drain".
GerryLP:cool
I do not have an MSD box, every thing is original EXCEPT: I replaced the motor with a new GM crate (stock) and unplugged the distributor computer wires since I added a vacuum dist. and added an 80 model carb. The computer is still powered as I only unplugged it from the distributor, if that makes sense. Keep asking if / how to remove the power from the computer and if that is the source of the drain on the battery.
The courtesy lights were a problem with batt drain, but that has been repaired. Whatever the drain is, it isn't much since it takes more than 4 weeks to pull it down.
Thanks for any help you can send . Mike J.
