I looked at a 78 Silver Anniversary a couple days ago and would like members thoughts on a couple points.
Body -- appears to be excellent EXCEPT the passenger mirror got ripped off the door! :eek Pulled the fiberglass right off in an area slightly larger than the footprint of the mirror. The mirror and fiberglass piece are still with the car. Any guesses on the cost to repair and repaint that section of the door panel?
Frame is solid, but one question here... The 78 had a single exhaust to the CAT, then split for a dual exhaust look. This frame has "holes" on the left and right for exhaust routing near the transmission. Another mint 78 I looked at only had the "hole" on the passenger side. What's up? Personally, I'd like to go with a true dual exhaust with tuned pipes, so this could be an advantage. I'm just not experienced enough to know if those transmission cross members came in different configurations.
The brakes are shot from non-use (the car hasn't been registered for 10 years). I don't have a big problem with this, since a stainless rebuild would be reassuring and kind of fun to do.
The engine runs rough. But, without brakes, I can't get a good road test. It is possible that the only problem is that the carb is gunked up and the wires are shot. Of course the whole fuel system would have to be cleaned.
Now that I've made it sound like a POS, let me explain that it only has 27,000 miles and can be had for something under $10,000. The interior is in excellent condition. So, the BIG question is... at what price is it worth the body, brake, exhaust and engine repairs to make this a cherry, low mile driver? :confused
Thanks for you thoughts.
