R
RaZr
xtra coolers
That was a typo on my part. Lube oil temp seems to run around 215 -220 degrees this time of year.
I too have an '05 Z51 MN6. Just curious about your comment on the 'oil temp of mid 120's.' Are you referring to the engine lube oil temp, or do you have a temp gauge on your trans cooler? I see only the lube oil temp on the DIC, which typically runs at 200 deg. when up to normal temp.
