Pseudomind
I have looked in the Tech Section and could not find it. I found the gear ratio's for each gear but I am looking for a chart which shows the maximum calculated speed for each gear at an established RPM range or even red line will do, e.g first gear top speed of 53 MPPH at 6,000 RPM.
I remember seeing this someplace before. I am referring to the stock 6 speed transmission in the 2003 Z06, which may very well be the same for the 2002, 2004 etc.
Hope this helps you
