"Corvette, 1989-1997, six-speed Corvettes with six speed transmissions have a dual-mass flywheel that is very expensive ($862 dollars), very heavy (over 40 lbs.), and they wear out.
We have a solution - we use a 1987 Corvette 4+3 flywheel, PN 14088646, which we can furnish, or you can get it from your dealer. Our Kit includes a special clutch pivot ball and a special clutch disc which features a unique friction material for long life.
Unless yours is badly worn, you can reuse your existing pressure plate. The end result is a very lightweight clutch assembly that will accelerate much faster and be easier on synchros. We have found the stock pressure plate to work fine - even on 500+ HP applications.
Note: There is a downside to this setup -- with the car idling with the clutch out there will be a clattering noise coming from the transmission. This will not hurt anything but it can be annoying. With the clutch depressed the noise goes away. The noise has always been there but has been dampened by the dual mass flywheel.
