itsa64
I am in the planning stages for swapping in a zz4. Can I use my existing rams horn exhaust manifolds to my sidepipes? I may lose some HP correct?
itsa64
itsa64
When I put my ZZ4 in last year I used the rams horns and std exhaust. Everything bolts up just fine and no leaks. I did not however look at the installation for performance issues so I didn't care about any slight mismatches that would cause restricted exhaust flow so I can't offer you any insight there. I installed them for the first startup of the motor and for the break in period because I didn't want to overheat my new headers reving the engine for 20 minutes breaking in the cam. Afterwards I found out I wasted my time and energy, the ZZ4 motor does not require the high rpm break in period.
Question 3: The ZZ4 has serpentine belt system, so if I do a swap do I need a whole new setup for my power steering pump?
The ZZ4 doesn't have any belt system in it's stock delivery from GM Performance. You can put a serpentine setup on it just as you could any engine that you wished to convert. But it ships from GM with no pulleys of any type. (For what it's worth, I'm running March Underdrive Pulleys on my car with no problems.)Question 3: The ZZ4 has serpentine belt system, so if I do a swap do I need a whole new setup for my power steering pump?
One thing at a time. Doing a trans-swap is not cheap from what I can recall. It's not a plug-n-play swap. Take you time and enjoy your car as you slowly build it up. I would say that most of our cars are an evolution (intentional reference) that takes place over time. With the engine out, it would be a fine time to replace the clutch pack, but other than that, I'd definitely hold off on a trans swap if you're trying to adhere to a budget.You guys are awesome! Thanks for the tips...
One more ???. Can I keep the original 4 speed manual for now or should I be lookin' at the new 5/6 speed tremec's???
I am on a budget..................... :confused
The Tremec 5-speeds (Keisler, etc.) are a great solution to the compromise between street performance and highway fuel economy, but will leave about a $3K hole in your budget. I wrote a step-by-step photo-illustrated article on a Keisler 5-speed install in a '65 in the April '07 issue of "Corvette Enthusiast" magazine.![]()
