loup68
Has anyone else had a problem with their clutch when using the smaller GMPP 153 tooth flywheel on a ZZ4 ? I had a 68 L-79 and I wanted to keep the stock, one year only starter. Everything is stock, bellhousing, 10 1/2 " clutch,bell housing ball stud. When I tried to adjust the stock type diaphram clutch, The adjustment was off the end of the clutch rod. I ended up getting a thicker "racing" throw out bearing to compensate, from summit. At first I thought I had put the fork on wrong and was kicking my self. But it was correct. Has anyone else had this problem? The only thing that I can think of is that the flywheel thickness has to be different than the normal 350 164 tooth flywheel.
