1959 fuel fill in California
olguy
New member
Spring Lake, Mi
1959 Mille Miglia Red
Hi guys,
I'm new here..I had a '59 with a 350 engine/trans in Mi. Never a problem...got old and gifted it to my son in California. It sat for a few years and he's had it kind of updated. He's had a new fuel tank put in it, added an HEI distributor and a new Holley 650. Other than a stuck lifter, all is sorta well....but....he can't fill the tank from a pump at a normal rate. He says he can only dribble the fuel into the tank...WHAT GIVES??? does anyone have any answers??
Toms007
Moderator
Southwest Kansas
2007 Atomic Orange Coupe
First off...Welcome to CAC!:w Next, Our resident 59 expert, Tom, should be by here soon to give you some help. But I might offer this; beings a new fuel tank was installed, is it possible that they might have kinked the hose that connects the filler neck to the tank? Without me actually looking at it and seeing with my own eyes, that is what it sounds like to me. Hopefully Tom will be by soon for you.
Tom Bryant
Administrator
Edgerton, Ohio, United States
1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
Welcome to the CAC.
The fuel filler pipe is the old style large opening and the connector hose is rather short so no chance of it being kinked that I can see. I don't know much about those fuel pump nozzles with the vapor recovery boots on them but they should allow the tank to vent while filling. Also there is a rubber vent line from the top of the tank that vents in the gas fill area beside the filler cap. That should not create any problem though with the vapor recovery nozzle working. It should be as easy as filling a gas can.
I'd run something flexible down the fill tube to see if anything is blocking it and preventing fuel from flowing freely. There should be no restriction between the cap and the tank.
Tom
olguy
New member
Spring Lake, Mi
Thanks guys, I've forwarded this to my California son. I'm sure he'll take note.
