Vader
I'm doing some research for an acquaintance. I've performed a couple of unproductive searches, and hope that someone here can give me details or direction.
The car in question is a '67 convertible, 427 L36 (sub-code JD) with 3-two barrel H2600s and a Powerglide. The car is bone stock (show variety).
The questions are:
I'm curious about the heads and valve train, since it may get a "stealthy" roller retrofit and decent lift with shorter duration to keep the cylinder presure down enough to run 91 octane pump gas, without detonation. I (we) don't want to open the chambers, install dishes, or ¼" heads gaskets. If at all possible, dynamic cylinder pressure will be controlled via the valve timing. It doesn't get many 1320 runs, unless they happen to be the distance from the entrance to the booth at the show. He'd like to be able to achieve a bit more driveability without frequent visits to the local airport for 100LL.
Any help will be noted and appreciated, even if simply a link to more information.
The questions are:
- Are the heads iron on the L36? Casting numbers? I know the L71 used aluminum heads, but...
- Is the L36 a hydraulic lifter design?
- What are the cam specifications / part number?
- From what I've been able to determine through web searches is that the CR is 10.0:1, but the owner reports having heard 11.0:1. Any clue which is correct, or niether?
- Short (standard) deck height on the old 427?
- Torque converter K-Factor (stall RPM)?
- Standard 105# valve springs, or did they install real springs in '67?
