Bolisk
I have a very early 1970 Corvette (Feburary). I also have the 1970 Corvette assembly manual. One of the things that I have noticed is that on several occasions, the assembly manual (especially the "updated" pages) do not match how my car was assembed.
Case in point, the Speedo cable routing. My 1970 assembly manual shows the speedo cable being sent through the firewall via a gromet to the right (looking aft) of the master cylinder (e.g. between the drivers side fender and master cylinder). Form there the cable goes straight into the back of the speedo.
This is NOT how my car's speedo cable is routed! There isn't even a hole in the firewall, where the assembly manual says there should be one. My car's speedo cable enters the firewall about a foot directly lower than where the tach cable & oil pressure line enters the firewall (on that angled buttress on the opposide side of the master cylinder). From inside the car, the speedo cable enters the foot box to the right of, and sligtly lower than the steering column. Is this right? Is this how the 1969 cars were routed? I'm guessing that my car is so early that it still has some of the 1969 parts on it. . .like maybe the firewall.
My next and last question is, if the above is correct, how / where do I rout the speedo cable in the dash? If I attempt to rout the cable behind the break and clutch than up to the dash. . .it reaches, but it interferes with the clutch pedel operation. Do I rout it between the break and clutch, or between the accelerator and break? Does it go over the steering colum, or under. . .etc. . .etc. . .
Thanks for any help I can get!!
Best Regards,
-Bolisk
Best Regards,
-Bolisk
