Hi folks -
I think my recent acquisition needs a horn relay. The little unit under the hood near the master cylinder "clicks" but I get no tone. I looked at Corvette Central ($20) and Eckler's ($70) but the Eckler's one looks more like mine. Mine also has a stud for a wiring terminal feed-3 wires are on it. Any thoughts?
Regarding the temp gauge. When cold, the needle is just below the 100 deg. mark. When warm, it is just over the 100 deg. mark. It doesn't even get halfway towards the center (210 deg.) mark. Is this probably just the sending unit? The heater blows warm air, and there is a 180 deg. thermostat.
Also, I assume the sending unit is on the driver's side head, green wire between #1 and #3 spark plugs. Correct? But I also see a wire going to something on the passenger side head between #6 and #8 spark plugs. This is a smaller green wire that goes to a blue wire (black GM terminal) that's in the starter harness behind the head, back of the block. What is this? I can't tell if it's a sender unless I take the ignition shielding off. The shielding does have an intentional circle shaped hole cast into it to allow this wire to pass through. Thanks in advance for your input.
Rick
Rick
