Timrock
1978 Coupe:
It is too much work driving my car! There is no play or give in the steering. The slightest bump and the wheel jerks. The car is in great shape and does not need front end work. The alignment is good. The car rides straight. Why is the steering so sensitive? Is there a way to "loosen" it up and give it a tiny bit of play?
I have just read the piece by toobroketoretire and I'm thinking that might be the answer to my problems. Tirepressure! My car has the 25560R15s. I have them set at 32lbs. The car rides really hard and is hard to handle. I really would like my wife to be able to drive this car, but as of now that's not likely. I'm gonna drop the pressure and see if that resolves the the issue?
I see that this issue is very common on the web, and have been reading about it, but there does not seem to be one good answer. Should I have the car re-aligned? The recommended settings seem to be all over the place. What are the proper settings? If the car is not fun to drive, why have it all?
I do have to replace the steering pressure vlave because of a slight leak, but that can't be the cause.
Please help!!
Please help!!
