1
1978L48jafo
Hi all,
My winter project was the rebuild of my L48 engine and it is ready to go back once I have new paint on the firewalls. I also decided to rebuild the heat/AC box, the AC was not worth using.
Question 1 My dash pad is not cracked but I would love to remove so I can dye to match my new interior and clean away 25 or so years of dust. How hard is the dash to get out? The only items still in the dash is the steering column and speedo and tach. The manual shows 4 or 5 bolts accross the top. My fear is that I will need to bend it to remove and end up cracking the pad for my trouble.
Question 2: I also need to remove the trans to replace a leaky front seal. Can the engine and trans be installed as a unit or is there is insufficient clearance?
Thanks in advance.
John McQuaid
Thanks in advance.
John McQuaid
