B
bruce20161
I found a 1979 c3 vette it has aprox 93000 miles it has been repainted some bubbling on head light area,the motor has some slight mods to it,carb,cam, headers just from what i can see.The car has power windows they work but drivers side is slow and does not seal at the top,hood right side by windsheild is up about a 1/4 inch some rubbing on the doors and hood paint comming off there is a crack all the way thru the fiberglass on the rear right fender above the wheel running from the center of the wheelwell opening up about 3 inches.The radio(after market)does not work the head lights come on but do not open.It will need all new body mounts as these are split and rotted it starts and idle's ok rev's ok oil,volts ok.I did not get a chance to drive it yet.there is good tires still on the car.I did shift it to D the N then R with no odd noise and solid feel the torq converter has been change to a higher stall. little rust but other wise clean under the car.They are asking $9900.00 He said that they would look at any reasonable offer.It is a classic car dealer offering 3000 miles and or 30 day warranty.I have not had the chance to get it up on a lift but they said that they would do so i can look under it more.What do you all think.it is about a hour's drive from my home.
