S
sac001
OK, I started a rear end job on my 80 4 speed a month ago, and I'm now getting everything back from the shop to reinstall.
My first question is, when installing new Brake Hoses into the refurbished Calipers, should I put anything on the threaded part of the hoses (teflon tape, anti-seize or the like)?
I will replace the brake fluid with new silicone type, is there a specific brand I should look for?
I'm replacing all the Calipers, rubber brake hoses (with Stainless Steel braided), have had the T-Arms, axle half shafts and differential refurbished. I'm sticking with the original spring, and replacing all the associated hardware and bushings/cushions.
Any suggestions will be apreciated.
Thanks,
Steve
Thanks,
Steve
