1981 Performance Upgrade help!!!
  • Thread starter Thread starter 81Coupe
8
81Coupe
I have apparently an L81 in my coupe. I am looking for suggestions on how to squeeze out a few extra ponies, without doing a major teardown of the engine. Anyone have ideas. Anyone ever installed a chip for their 81. Apparently Hypertech or ADS makes one to modify the air/fuel mix and shift points. Thanks all!!!
81Coupe
Take a look at this THREAD from the recent past, it has some good simple things you can do to up the HP fairly economically.
As for the "chip" I tried one in mine and didn't notice enough of a change to suggest buying one, I "think" I had a little more pulling at higher RPM but could have been wishful thinking too ;), Mine is a 4-Speed so I don't know if an Auto would make much difference, if you would like the chip I have, and if I can find it I'd be happy to send it to you..
BudD
:w
81Coupe,
On my '81, I put Alumincote 5000 headers and a replaced the three-stage Cat with a two-stage; 3" pipes back to stock mufflers, removed the AIR pump and plugged up the plumbing. There was a very noticeable increase in torque and accelleration. Also gas mileage went up too. Just ran from 1300 miles round trip lugging my 200lb son with me and w/o AC running got 22.6mpg twice. I will hopefully have an opportunity to put her on a Dyno in September and once and for all get a reading on the exact increase achieved. Oh yeah, still passes the (very tough) MD emmisions test with flying colors. The whole upgrade was under $400 about 10 years ago.
Good luck and Welcome to the CAC. Never hesitate to ask a question, we're all here to help.
....... Nut
Torque Shop
Dream Giveaway
