G
		Genna1
I have a '91, and was curious about other's opinions on this before I go ahead and actually do it; on a stock 85-91 that has all the original air filter lid and ductwork, etc, I was curious - if you remove the air filter cover/lid, and then the air filter, can you cut a hole the same size as the air filter through the bottom of the air filter holder assembly, down through the fiberglass radiator shroud so that the cold air that comes up under the front spoiler that helps to cool the radiator can also be sucked up into the air cleaner assembly? I have seen other cone-style K&N set-ups that have cut a smaller hole through the shroud to help draw in colder air, as well as the style that draws air in through the front license plate. I have 2 concerns about trying this set-up:
1. Will cutting a hole through the fan shroud affect the efficiency of the cooling system in anyway? I have heard that on the C3's, if the shroud doesn't fit tightly around the radiator/fan assembly, or if some of the insulating foam is missing, the cooling capacity can be affected. I'm wondering if cutting the shroud could have a minor negative effect on the cooling system as a whole?
2. Will the resulting hole draw in heated air as well as cold air, since it would be in such close proximity to the radiator? Also, would I need to worry about it if I was driving in the rain (no major floods, just everyday rain)?
I know that there are many relatively inexpensive cold-air kits that are available out there today, however I was just curious if this would be a viable alternative as well; with the air filter and lid in place, it would nearly be undetectable from stock, since the hole would be cut under the air filter assembly itself, and hidden from view when raising the hood. Any thoughts or opinions are welcomed..........
Thanks, Chris.
Thanks, Chris.
