I'm working on a 1929 Ford Truck street rod, with a 1987 Corvette tune-port injection system. Very nice ride, has an after market wiring harness, no a/c system on truck, has 3 speed automatic transmission. It will run but you can un-plug all 4 injectors on left bank when running and has no effect on performance, it runs really bad. I have ignition fire, have 150 psi compression at cylinders, have fire to injectors, have correct resistance on injectors (14 ohms cold)(17.5 warm), have checked ground issues, new distributer, cap, rotor button, ignition coil, have tried another ECM, tried to set idle counts (reading stay's high 80-105) should be below 70 counts for correct idle, have set tps(0.54 ohms),mass air flow also staying high(8-11 ohms) spec's 4-7 ohms. Have drove truck alot to try and re-learn ECM, still runs badly. Owner states the truck has been this way for some time. NEED HELP PLEASE ANYONE.
