1990 ZR-1 / LT-5 engine
L
lt1george
Can someone please tell me for sure if the 1990 ZR-1 engine block has the drain hole for the strarted so water does not collect by starter. The covette technician at the local Chevy Corvette Dealer says it does not have it. I have told him that I read a post here, that I believe Rob wrote about a month ago that said the hole is there . Can someone please help and confirm for sure .Thank you. Save the Wave.>George
Jeffvette
Battle Ground, WA
It does have it, it got bored out to make it a bit larger in the later years.
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
The hole is there and I saw it with my own eyes under the starter of my 1990. As JeffVette already pointed out, the size was increased in later model years.
The problem with the earlier version is that if water and enough road salts and debris get in there, an amalgam can form thus blocking the hole. If the hole gets blocked, any water that gets up in the engine compartment can find its way into the valley of the engine. If the engine isn't hot enough to burn it off, it can sit there and eventually corrode the starter contacts.
S
Steel Half-Shafts
[Hint:] Everytime I do an oil change on my ZR and it's up on the ramps, I blow a little compressed air from my portable air tank up through the small 3/8" sliver drain tube coming from that drain hole. The drain tube exits between the oil pan and bellhousing on the passenger side of the engine tucked up in the gap.
Keeps it Nice and Clear. :upthumbs
