daved2
I just picked up a 1992 LT1 and all the vacuum lines and engine were in boxes. I got everything straightened out but the vacuum lines. I am wondering where the main line that feeds the vacuum tank comes from? I have the vacuum lines on the drivers side and the line coming off the cruise control and it has a T fitting on it, I also have a line coming out of the wiring harness under the brake booster. What I need to know is does that line coming out of the wiring harness feed vacuum to the tank and cruise control? I know the lines on the driver side of the engine go to the EGR then T off at the manifold and go to the ASR module and stop there or does it go to the tank or cruise control?
I'm thinking with the connections I see there that the line coming out of the wiring harness near the booster feeds vacuum from the other side of the manifold where there are two vacuum lines coming out of the wiring harness that go to the passenger side manifold and both of them feed off of the manifold with a check valve from the lower port or one of the two ports on that side of the manifold and the other one there just feeds the fuel pressure regulator, Am I correct?
Or does that line on the driver side go to the EGR then the manifold then the ASR then the tank and cruise control?
So basically I have three vacuum lines coming out of the wiring harness near the firewall, two on the driver side and one on the passenger side below the brake booster and don't know how the hook to the tank, or where the tank actually gets it's vacuum from?
Thanks guys!
Any help would be appreciated.
Thanks guys!
