RMitchell
New member
I recently purchased a 1994 Admiral Blue LT-1 Coupe. The antenna mast does not work, so I have even trying to replace it. When I removed the antenna mast, with a slight tug it came out, there was a rotten and bent inch long piece of broken antenna cable. Unfortunately, I have no clue how to get the rest of the cable out of the motor. I removed the rear left tail lamps to get a better view, but that hasn't helped any. Is there any way that I can get the old antenna cable out, short of removing the wheel housing and replacing the motor!?
Thank you so, so much for any advice; I love this car so much and want it running as best as possible!
-RMitchell
(P.S, I bought an antenna replacement kit from Corvette Central, if that changes anything!)
-RMitchell
