Hi,
I've tried to use the search feature but couldn't find anything, I apologize if there is already a thread on this subject.
I was trying to replace the center high-mounted stoplamp on my '96 (it's not really mounted high on this model, it's just above the license plate) but the glass portion of the bulb detached from the screw base and the socket appeared to be melted. I need to replace the socket but I'm struggling to find the correct replacement.
I've looked on a couple of part websites and cannot find a high-mounted stoplamp specific socket, however I have found the back up lamp socket (which according to the owners manual both the back up light and center high-mounted stoplamp use the same 1156 bulb), does anybody know if this socket will work?
Here is one I found... http://www.parts123.com/parts123/yb...~S3MD0MR0CM701141167050~Z5Z5Z5~Z5Z5Z50000050F. Looking at the picture it seems a little different from the socket I removed so wasn't sure if it would work.
Thanks in advance.
Thanks in advance.
