1999 coupe a/c light flashes and turns off
8kgold69
Sanford,FL
1969 R.Gold CV. Original 8K miles. Pilot 1970 LT1
Hello folks
I hope everyone had a good Christmas and a Happy New Year. Now down to business. I have a 1999 Coupe, 6 speed, Z51 option. The vehicle has 26,670 actual miles. I live in Florida, so yes we still need the a/c to work. The car is equipped with the dual zone a/c option. When I press the a/c button, the yellow/orange light blinks several times but then stays off and the a/c does not come on. The system is full of freon. However, I notice the LED screen consistently reads EXT 25 degrees F, no matter what the out side temperature is. I did replace the drivers side temperature control actuator, because when the a/c was working a couple days ago the passenger side was cold and the driver side was hot. I also checked the the computer for codes and there are none in the DIC. I have a friend that is a tech and he checked the system with his Snap-On computer and said that it could be the control unit in the dash. Any ideas, comments, etc...?
8kgold69
Sanford,FL
Hello
Any body out there?
LLC5
Wa.
98 black 6spd convert.
Hello folks
You answered your own question. The a/c will not operate if the ambient temp is showing 25*F and the a/c light will flash telling you it will not operate. You need to repair why the ambient temp is reading low, the sensor is behind the front bumper I believe. The ambient temp needs to be above a certain temp for the a/c to work, it should be in your owners manual for the exact number.
8kgold69
Sanford,FL
10-4 Thanks for the reply. I'll change the temp sensors.
