#2 ** No Spark?
  • Thread starter Thread starter 85Fever
8
85Fever
ignition module has been replaced. So far everything in the distributor has been replaced, and I have 12v at the battery terminal of the distributor.
Assuming that everything in the distributor is good, is there anything outside of the distributor that could cause a no spark condition?
Camshaft gear ??? Is the rotor turning when you crank the engine?
Andy
response
Yes and every part has been replaced. It does not seem possible to run some of the test that are in the book. Look at the other post that is labeled no spark 1985 tpi, that is where the discussion is and I posted the picture of the service manual. Please take a look! :w
Andy
