2001 Z06 alignment
Hib Halverson
CenCoast CA
Forum members-
Perhaps a little known service fact about the Z06 is that it has different alignment specifications than all other C5s.
Through an unfortunate error, the 01 Corvette Service Manual does not contain the proper alignment specifications for the Z06 and, up to now, GM has not provided the proper specs to dealers through the TSB process. That may happen later this year, but until then, the proper alignment specifications from sources in GM that deal with Corvette service issues are published below. The 02 Manual will contain these specs.
Front Individual Toe +0.04 degree +/- 0.10 degree
Front Sum Toe +0.08 degree +/- 0.20 degree
Front Individual Caster +6.9 degree +/- 0.50 degree
Front Cross Caster within +/- 0.25 degree
Front Individual Camber -0.70 degree +/-0.50
degree
Front Cross Camber within +/-0.25 degree
Rear Individual Toe -0.01 degree +/- 0.10 degree
Rear Sum Toe -0.02 degree +/- 0.20 degree
Rear Individual Camber -0.68 degree +/- 0.50 degree
Rear Cross Camber within +/- 0.50 degree
Hib,
Thanks much for the information.
I have enjoyed and found useful numerous articles you have written for various print publications over the years.
Ray
Hib, where can I find the alignment specs for my 99 C5?
Herbie
Torque Shop
Dream Giveaway
