hub_cap
- Joined
- Sep 2, 2003
- Messages
- 41
- Location
- Marietta, GA
- Corvette
- 2003 50th AE Convert, Auto, '04 Z06 CE #174
59th AE has started being hard to steer, fluid is at half full mark, no sign of leaking.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Inspect all power steering hoses. Replace as necessary.
If the steering fluid has never been changed, first thing I'd do is flush the system and refill to the full mark with fresh fluid. Bleed the system according to the Service Manual. Then road test. Drive the car a while to warm the fluid then compare the current steering feel with what it was before.
If, after flushing and refilling, if steering effort is still high, you may need to replace the pump and or the rack.
Thanks as,always, Hib. Fluid never changed with 55k on the car. Time to do it.
Fred Hale
