2014 Chevrolet Corvette Stingray Preliminary Specifications
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
[h=3]2014 Chevrolet Corvette Stingray Preliminary Specifications[/h] Overview | Engines | Transmission | Chassis/Suspension | Brakes | Wheels/Tires | Dimensions
[h=2]Overview[/h]
<tbody>
[TD="width: 169"]Model:
[/TD]
[TD="width: 346"]2014 Chevrolet Corvette Stingray
[/TD]
[TD="width: 169"]Body styles / driveline:
[/TD]
[TD="width: 346"]2-door hatchback coupe with removable roof panel; rear-wheel drive
[/TD]
[TD="width: 169"]Construction:
[/TD]
[TD="width: 346"]composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components
[/TD]
[TD="width: 169"]Manufacturing location:
[/TD]
[TD="width: 346"]Bowling Green, Ky.
[/TD]
</tbody>
Back to top
<tbody>
</tbody>
[h=2]Engine[/h]
<tbody>
[TD="width: 174"]
[/TD]
[TD="width: 343"] LT1 6.2L V-8
[/TD]
[TD="width: 174"]Displacement (cu in / cc):
[/TD]
[TD="width: 343"]376 / 6162
[/TD]
[TD="width: 174"]Bore & stroke (in / mm):
[/TD]
[TD="width: 343"]4.06 x 3.62 / 103.25 x 92
[/TD]
[TD="width: 174"]Block material:
[/TD]
[TD="width: 343"]cast aluminum
[/TD]
[TD="width: 174"]Cylinder head material:
[/TD]
[/TD]
[TD="width: 174"]Valvetrain:
[/TD]
[TD="width: 343"]overhead valve, two valves per cylinder
[/TD]
[TD="width: 174"]Fuel delivery:
[/TD]
[TD="width: 343"]direct injection
[/TD]
[TD="width: 174"]Compression ratio:
[/TD]
[TD="width: 343"]11.5:1
[/TD]
[TD="width: 174"]Horsepower / kW:
[/TD]
[TD="width: 343"]450 / 335 (est.)
[/TD]
[TD="width: 174"]Torque (lb-ft / Nm):
[/TD]
[TD="width: 343"]450 / 610 (est.)
[/TD]
</tbody>
Back to top
<tbody>
</tbody>
[h=2]Transmissions[/h]
<tbody>
[TD="width: 33%"]Type:
[/TD]
[TD="width: 31%"] seven-speed manual with Active Rev Match
[/TD]
[TD="width: 34%"] six-speed paddle-shift automatic
[/TD]
</tbody>
Back to top
<tbody>
</tbody>
[h=2]Chassis/Suspension[/h]
<tbody>
[TD="width: 174"]Front:
[/TD]
[TD="width: 343"]short/long arm ( SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite spring, monotube shock absorber
[/TD]
[TD="width: 174"]Rear:
[/TD]
[/TD]
[TD="width: 174"]Active handling:
[/TD]
[TD="width: 343"]Magnetic Selective Ride Control (avail. with Z51)
[/TD]
[TD="width: 174"]Traction control:
[/TD]
[TD="width: 343"]StabiliTrak, electronic stability control
[/TD]
</tbody>
Back to top
<tbody>
</tbody>
[h=2]Brakes[/h]
<tbody>
[TD="width: 169"]Type:
[/TD]
[TD="width: 348"]front and rear power-assisted discs with four-piston fixed front and rear calipers (slotted rotors with Z51)
[/TD]
[TD="width: 169"]Rotor diameter (in / mm):
[/TD]
[TD="width: 348"]front: 12.6 / 320 (13.6 / 345 with Z51)
rear: 13.3 / 338
[/TD]
</tbody>
Back to top
<tbody>
</tbody>
[h=2]Wheels/Tires[/h]
<tbody>
[TD="width: 169"]Wheel size:
[/TD]
[TD="width: 348"]front: 18-inch x 8.5-inch (Stingray)
front: 19-inch x 8.5-inch (with Z51)
rear: 19-inch x 10-inch (Stingray)
rear: 20-inch x 10-inch (with Z51)
[/TD]
[TD="width: 169"]Tires:
[/TD]
[TD="width: 348"]Michelin Pilot Super Sport run-flat
front: P245/40R18 (Stingray)
front: P245/35R19(with Z51)
rear: P285/35R19 (Stingray)
rear: P285/30R20(with Z51)
[/TD]
</tbody>
Back to top
<tbody>
</tbody>
[h=2]Dimensions[/h] Exterior
<tbody>
[TD="width: 198"]Wheelbase (in / mm):
[/TD]
[TD="width: 319"]106.7 / 2710
[/TD]
[TD="width: 198"]Overall length (in / mm):
[/TD]
[TD="width: 319"]177 / 4495
[/TD]
[TD="width: 198"]Overall width (in / mm):
[/TD]
[TD="width: 319"]73.9 / 1877
[/TD]
[TD="width: 198"]Overall height (in / mm):
[/TD]
[TD="width: 319"]48.6 / 1235
[/TD]
[TD="width: 198"]Weight distribution
(% front / rear):
[/TD]
[TD="width: 319"]50 / 50
[/TD]
</tbody>
Back to top
<tbody>
</tbody>
I'll have all of this data properly formatted in the C7 section under the Specs tab above at a later date.
Thanks for getting us this information. Also for those great technical photos you just posted this morning! I actually like those as much or better than photos of the car. Your photos of the car were great by the way. I get angry at GM for their photos taken 2 inches from parts of the car and them playing coy with the photos. Stop the drama and show us the photos, GM!! Their come on videos the last few weeks were total garbage.
Photos are posted in the gallery.
Weight?
Why the estimate on the HP? They have had this engine on the dyno hundreds of times. They should know what the HP is.
