- Admin
- #1
#PIP5337E: Shake Or Shudder On Acceleration Excessive Engine RPM Fluctuation Between 30 And 65 MPH - (Aug 15, 2016)
Subject: Shake Or Shudder On Acceleration Excessive Engine RPM Fluctuation Between 30 And 65 MPH
Models:
2015 - 2016 Cadillac Escalade, Escalade ESV built prior to 11/01/15.
2015 - 2016 Chevrolet Corvette, Silverado built prior to 11/01/15.
2015 - 2016 GMC Sierra, Yukon, Yukon XL built prior to 11/01/15.
Equipped with 8L90 Automatic Transmission (RPOs M5U) and the 6.2L (RPOs L86 and LT1)
Note: This information does not apply to Silverado and Sierra models with the 5.3L (RPO L83).
Please refer to bulletin 16-NA-175 for vehicles equipped with 5.3L (RPO L83)
This PI was superseded to update labor time. Please discard PIP5337D.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some customers may comment on any of the following conditions
A shake or shudder during light throttle acceleration, between 30 and 65 mph steady state driving.
Excessive engine RPM fluctuation that may be described as frequent tachometer needle movement at constant speed when engine speed is below 1600 RPM.
A shudder feeling that may be described as driving over rumble strips or rough pavement.
It is important to note that these conditions:
Do not occur during vehicle launch from a stop.
Do not occur when the transmission is shifting gears
Do not occur when the vehicle is decelerating.
Do not occur when TCC slip speed is zero. TCC slip speed is zero in gears 2-8 when engine RPM is greater than 1600 RPM.
Link: 2015 - 2016 Corvette: Service Bulletin: Shake Or Shudder On Acceleration Excessive Engine RPM Fluctuation Between 30 And 65 MPH
Models:
Condition/Concern
