2015 trunk light fuse
67vet
Oregon Ohio
2015 Z06 Callaway White, 1967 Corvette RestoRod
Would someone please tell me where the fuse is located for the trunk light in a 2015 convertible. :w
MacMulkin Chevrolet
Nashua NH
1990 Corvette ZR-1
Try the #23 fuse in the rear fuse block .. labeled as 'Rear Closure'
MacMulkin Chevrolet
Nashua NH
1990 Corvette ZR-1
Actually, correction, try the #22 fuse - see attached.
67vet
Oregon Ohio
Thank you very much for your help up to this point. :w
After research I found that I had waited over 15 minutes to change to the new led bulbs.
So, I closed the trunk and found that I could only open the trunk lid with the key.
The good news is that the new led lights work great. The bad news is the trunk won't open electrically.
I have checked the fuses with a multi meter, including number 23 - rear closure. All the fuses check OK with the meter.
Both the rear electric button above the license plate and the drivers trunk opening button do not work.
Help is needed, :ugh
Thanks,
Roger
67vet
Oregon Ohio
Also, the names and the numbers on the chart that you posted do not match my 2015 names in either the owners manual or on the panel above the fuses in the trunk. :w
Roger
