Pro Street
When I did my cam,valve springs and headers I installed a 25% underdrive crank pulley.My car is running about 20° warmer now at highway speed and idle.Are any of you guys seeing the same thing?
Does the pulley drive the water pump? :confused Unless you run an electric water pump the under drive cut the pump output by about 25 percent .
