80VetteL82 said:
I was thinking about that...so the 700r4's 1st gear is just like having a 3.73 rear? So what would happen if you had a 3.73 rear w/ a 700r4, too much? I had been leaning towards a 200-4R because its supposed to be a better swap for the TH350. Thats got a less agressive 1st so 3.73s would be good with that right?:W
Correct about the 200R4 and gearing. Also, the 200R4 is a direct fit, where as the 700R4 requires some customizing (new crossmember, shortened drive shaft, etc).
However, the 700R4 with an actual 3.73 rear would give you somewhere in the 4.xx range for a first gear, but your cruising rpms would still be much more tolerable.
You can go out to Bowtie Overdrive's site
700R4.com and somewhere in there they have a chart of the combinations. Also, somewhere in this C3 section, I posted pics of my speed-vs-RPM's with the stock 3.08 rear and the 700R4.
On a side note, some people register complaints about the 700R4 because the 1st & 2nd gear are so far apart, that unless you are really running at WOT from the start, it's not the best transmission for racing or whatever. I'm not exactly how the argument is phrased, but it has something to do with the difference in gearing between 1st and 2nd...
Here's the link to my post with the RPM -vs- Speed pics...
Clicky!
