HD2KC162
350 that I just took out of my 62 is now for sale. 350, "010 block", 4 bolt mains, 30 over, big valve heads, 9.5:1 compression, L46 cam(350/350), PCV set up like 1969 L46,Mellings oil pump, Flo Kooler water pump, Edelbrock aluminum manifold, 1850 list Holley 600 CFM, Mallory tach drive electronically triggered distributor with vacuum advance control and Mallory Coil. K&N air filter, Aeroquip fuel line and Russel filter, OEM Corvette polished aluminum valve covers used on L46, LT1, L82 engines.Hooker inside frame headers. Engine is complete from fan and fan clutch to flywheel and clutch and from pan to air cleaner. 1962 front engine mount bar is in place. Less than 5000 miles on the engine. Also have an aluminum bellhousing and suitable starter and generator and 901 and 902 exhaust manifolds available if needed. Engine located in Eastern PA(Bucks County) $3000 for a turnkey engine Send PM if interested
FINALLY put the restoration 327/340 into the 62!!
