minifridge1138
What do you get when you fire on 1/2 of your cylinders? My car.
Went out to drive it over the weekend.
It fired up, no problem.
Gave it a small amount of gas to back out of the driveway and it almost died.
Gave it a good revving, and it jumped to 2,500 RPM and kept going no problem.
It ran fine the previous time I drove it (maybe 1 week) and I made absolutely no changes, modifications, or "improvements."
It was just parked in the garage.
Here is where I am:
I have disconnected every vacuum line going to the carburetor and intake manifold, that made no difference.
I replaced the cap and rotor (they were old and worn). That made no difference.
At idle, I disconnected the plug wires from the distributor 1 at a time. Pulling plug 1, 4, 6, or 7 made no difference to the idle.
Pulling plug 8, 3, 5, or 2 caused the car to die.
So at idle, I seem to have every other cylinder.
There is a range between idle (~600 rpm) and 2,000 RPM where the car tries to die.
2,000 RPM and above and it seems completely normal.
Any ideas? I'm sort of stumped.
Thanks everyone!!!
Here is where I am:
Thanks everyone!!!
