I
Igor
Hello everyone.
So I am going to buy a vette my friend is selling. I am not new to sbcs but i am new to TPI AND Y body.
Here is what the car has (1985 Z51 automatic):
a zz3 crate motor w/a nasty knock in it.
Accel lingenfelter intake, I assume a super ram (its the big flat looking intake on the top, like a box)
headman or hooker LT headers, dual 2.5" exhaust with off road x pipe and magnaflows
new built 700r4 with a 2400 stall converter
3.08 rear diff, i assume the weak dana 33 or whatever it is
I think a 52mm TB and 24lb injectors
a mail order chip with lifetime free updates (1985 style)
I had a few rides in the car just prior to the knock. Ran strong and tranny shifted real well.
What I Have:
.040 400 with 2 valve relief flat tops, forged, -5.4cc, molly rings
5.7 rods with arp hardware, cleranced for cam
stock crank cut .010/.010
arp main studs, arp head studs, full machine work inc. balancing
short block is done so i do not want to change it. I want to do this on a budget.
I need a set of 70cc aluminum heads, that should put me in the 10.5-10.6:1 CR depending on exact deck height of my 400. I am hoping this would work with TPI. If I went with 67cc around 11:0-11:1 CR which might be too much. What is a good CR to run with pump gas TPI motors?
I'd look at some eddy RPM heads (cheap, on budget) or maybe something else for a similar price, but like i said budget is key.
I wanted to stick with a hydro flat tappet cam due to cost and a modest power goal. I just want to make this 400 work with the tpi intake/1985 computer as best i can. I want a car that is easy to drive in traffic, and does not rev too hard, but still makes use of the 2400 stall converter. Hyro Roller i know is the way to go, but it adds to cost significantly. You need the retro cam, lifters, button, etc. I have a SR in my 383 in an 88 trans am, but for this car i just want a daily driver. I have broken in dozens of flat tappet cams, I know you run the risk of them going flat, but i think it would work OK for this combo. Any idea what grinds would work OK with the 1985 TPI computer and a 400 combo?
I am assuming I'd need 30lb injectors and a new fuel pump. I'd get the chip sent back for a reflash to new speks, so i can break in the motor and drive it to the dyno for a real tune.
What oil pan do I need? I am understanding I CAN run a 168 tooth fly (what i have) but will need a smaller then 8" (6.25 or whatever) balancer?
Anything else I might be missing?
Thanks a lot guys.
What I Have:
Thanks a lot guys.
