The 6 link mentioned on CORVETTEFAQ wasn't a 6 link, it was a toe control setup. It was a bracket bolted to the back of an aluminium diff to supply a mounting platform for a toe control setup like the C4. However, the car still used trailing arms so something is a miss there, you can't use toe control rods with the stock shimmed trailing arms, the only way would be to just use the trailing arm bolts as locator pins and allow the assembly to slide (not using shims) but I'm not sure if they did it like that. It would be the easiest way to get rid of the toe control problem.
The toe control problem is the major C3 IRS problem. Like you said, the susp. scribes an arch and the trailing arm pivots at a fixed point, this changes to over the entire suspension travel. A bad thing! That was fixed w/ the C4, they have the dog bones, a set of sectioned trailing rods. There are 2 to control hub stability (rotation resistance) and because they are sectioned they allow free movement, a set of rear toe control rods controls toe obviously.
I used to have a mockup Dana 36 IRS from a late C4 (it had integrated parking brakes in the calipers, the earlier ones have drum praking brakes) The later models have a bette roll center than the early C4s which suffer from a jcking effect due to a high roll center (during cornering the outboard wheel jacks up the diff like a pole vaulter giving a severely reduced contact patch and a sudden loss of grip/reduced slip angle)
However I didn't use it, first it was a mockup ..the 36 is a weak unit, secondly the toe control is not 100% accurate and third the trackwidth is much wider and with my wheels that would mean even larger flares...too large. It uses a centrally located inner mount and long rods to give control that mimics the susp. travel but not perfectly. The longer rods give less angular effect and the toe control is off the more you get away from the neutral (straight halfshaft) pos. A better approach is building it w/ a toe control rod that hinges parallel and in line w/ the halfshaft and it's 2 u joitns. Then it will always be dead on eprfect (and that's what I built for my 5 link...the project that I dropped although finished...stepping up to double a arms)
The camber control is good on a stock C3, if the stub axles are tight and the clutch pack too..giving a slop free stub axle. This because the halfshaft is the upper control member (this is also true for the C4 susp). A 6 link adds 2 upper bars to allow you to remove the halfshaft as a geometric control member. Dragvette recently released a kit. They have no clear recommendation on what to do w/ the stub axle clip. However, for a true independence it's best removed and the bars so adjsuted that the stub is pulled a tiny amount out off the diff. However, there's a trucky part here. The rods must be placed absolutely eprfect for the pivots to be in line w/ each other and the u jonts and the 2 rods and the halfshaft have to point to the same instantaneous center. I'm certain they have that figured out properly but small tolerances will affect things, that's why I believe the clip is best removed. I think Norval was one of the 1st to install a 6 link. However these kits are for older differentials and can't be mounted on the later ones. I welded a subframe on my chassis for that, but decided the subframe would be perfectly suited for an upper control arm , the geometry is the same for 6 links and for double a arms, the arms just incorproate toe control and wheel axis location so another plane (birdseye view)
The only need for reduced camber gain is NOT because it always makes the car handle better, it may not. It has to do w/ lowering, the roll center , the center of gravity and most important body roll. Body roll is the result of lateral weight shift during conering (centrigugal force), so it's the weight shift that induces the roll...not the roll that induces thbe weight shift. The rolling is the suspension absorbing some of the weight shift. I have reduced body roll by lowering the CG, the roll center in the rear is raised, as is the front (the front being particularly poor, you can use some additional camber gain there, a longer uppre ball joint will help) and I have siff springs and roll bars. I have 400rera and 450 front springs, however they are all moutned on the spindle - rear- and on the control arm near the ball joint - front- so that the spring rate is much closer to the wheel rate (stock it's a nutcracker principle, the spring receives a higher load because the wheel is on the handle side of the nutcracker and the cross shaft is the hinge). This means I will have significantly less body roll. This gives 2 other problems, the load on the tires is severely increased, that's why I'm going to be running very wide tires front and back and with the stiff suspension the load put into the frame is increased also. No use in having a stiff suspension mounted on a weak frame, you won't be able to dial in or use the suspension if the frame is like a soft noodle, the frame will "soften" the susopension characterstics but in an unpredictable way. That's why I have all the frame mods.
There's a reason behind all the mods I've done, the coil overs, the dyno tuned and valved shocks (custom valved and dyno tested for resutls at varios shock oil temps) and so on.
Equal struts in a 6 link give NO camber change, something you don't want unless you're a drag racer strictly.
Stock trailing arm suspension
my 5 bar:
The forward mount
The toe control was not installed there yet. This is how I was going to do the toe control, never finished because of double a arms. However I do have all the design drawings for the toe control plate (and the toe control mounts on the hubcarriers were in place)
See those 4 allen bolts? Those 4 round bosses are cast into all the batwings, they are PERFECT for drilling and tapping (M12 allen heads), they are not in the same plane but nothing a simple set of spacers can't fix (on the top bosses) or an angled plate. This allows easy mounting of a toe control plate:
Here's how it is done ...this is the pic that was called 6 link!
A c4 toe control setup on a 80-82 diff by doing exactly what I did above, drilling and tapping those 4 studs. This car still uses the trialing arms, apparent by the coil overs (they are mounted on a bracket made of U channel welded to a trailing arm, these mods have all been done by acp in germany..that's how they mount it) so they must have removed the trailing arm shims, othrewide it'll bind. If they did, rpetty neat...and a cheap way to get rid of the toe control problem, cheaper and easier than building a complete C4 type suspension. However, since the shocks (coil overs) are mounted on the trailing arm this stresses them outboard (since the shocks are angled) that means that the trialing arm isn't free to move, the toe control rods have both the toe control force on them and part of the load that pushes the arm outside (since the coil overs mount front of the halfshaft)...for a proper free movement and recued load on the rod it'd be best to locate the shocks as close to the bearing carrier as possible.
Another thing is, it uses the central C4 mount, kind of a shame..it'd have been pretty east to build a bracket w/ 2 5/8th holes for 5/8 bolts and rod ends directly insight of the inner u joint..then toe control would be perfect.
This is my Toe control plate design (abandoned it, have a rough mockup..wanted to have it water jet cut..no use now)
Here's some shots of my mods:
Part of the rear lower arm mount, repositioned for a new wheel center (moved wheel axis backwards so it's centered in the L88 flares, most cars you see w/ those flares look like the wheels are too far forward, this because of the design of the flares...I think it's ugly so why not move the wheel back, the diff is also placed slightly further back) The rod end is for marking where the forward mount has to be on the pinion crossmember (although the threaded rod is not adjusted proeprly in the pic, it has to be parallel w/ the beams above the diff)
C4 Dana 44 & differnetial oil cooler pump / custom pinion mount (C4 uses a c beam...no room for that)
My chassis:
Here's my double a arm susp. design (I have already started building this)
same w/ cantilever shock setup and a billet aluminium lower arm (gotta figure out how much $$$ to have that milled)
Almost finished the uprights:
