1KULC7
For some reason I have a files saved on the Corvette Forum User section and the photo files are not loading correctly, so went to another site.
So I will try again, previous post --- Work is continuing for the road to Top Flight, I was not satisfied with several things and now am correcting them. The front wheel wells were really bad and needed restoration. Tore them apart, stripped them, and started all over. Undercoated correctly and here are the results:
The control arms were bolted together, removed stripped repainted and bolted them together. These are original 63 Ball Joints...
Gas tank was replaced with new one, exactly like original even with stencil...
Here is a shot of the ORIGINAL Build Number found on the fiberglass wall opposite the gas tank, removed tank and found it, in green crayon..
Finally, Reshot the car to make it look more like lacquar finish, dulling the door jambs and hood area....fixed couple other little flaws...
Hopefully all of this will come together by NCRS Mid Atlantic Chapter meet for judging June 3 and 4th....providing no more trips...:crazy:
