Tom, they should all be the same. It's possible that the upper and lower would be different due to the "door hold open" but I'd have to pull mine, which I can if you want, takes 2 minutes. I should pull them anyway to clean & lube.
"Hang right" doesn't help much, I could use a better description.
There's a boatload of adjustment between the hinges and the door. The hinge holes are slotted fore & aft so, you can move the door that way and change the angle of the entire door. PLUS the nutplates in the door are loose (confined in the door but can move at least 1/8th or so in all directions.
Now, if a gap problem and the body hasn't been off the frame, a body mount cusion may have failed. If the body has been off, the number of shims at each mount affect the gap (yea this part's real fun).
AND the striker nutplate in the back of the door jam is also moveable.
See, easy peasy, Huh?
I do have a description on door gap adjustment with the body mount shims if you need it.
Basically, it's a bunch of trial and error hours.
And the bolt locations on the hinges should have been marked when the doors were removed (20/20 hindsight).
Let me know if you need anything else.
