P
PIPER-68
DOES ANYONE KNOW IF THIS IS THE RIGHT CASTING # (3782870)
FOR A 64 327/ 365HP ENGINE ? IT ALSO HAS FOIIOS OR COUD BE F0110S ON THE FRONT RIGHT PAD . I AM TRYING TO PUT ENOUGH CORRECT PARTS TOGETHER TO BUILD A 327 / 365 HP FOR MY 64 . I WAS TOLD ALL I HAD TO DO IS CHANGE THE TACH TO A 6500 RPM REDLINE AND THE OIL PRESSURE GAGE TO A 80 LBS MODEL. IS THIS CORRECT INFORMATION ? WHAT OTHER PART # OR CASTING # DO I NEED FOR THE HEADS AND INTAKE TO MAKE IT CORRECT ? MY CAR WAS MADE IN JUNE AND I AM PLANNING ON DOING THE CORRECT RESTAMP ON THE BLOCK OR A COMPLETE RESTORATION.
THANKS , CHAD....
THANKS , CHAD....
