- Moderator
- #21
- Joined
- Nov 9, 2000
- Messages
- 7,556
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69), 1981 Beige L81(10/20/80)
That's good news about the steering wheel. My '65 had the teakwood wheel. Very nice option.
As for starting it, after you have all of the service work done I would take the plugs out and also check inside the air cleaner for any signs of mice nests. Squirt some Marvel Mystery Oil in each cylinder and turn the engine over by hand a couple revolutions to make sure it is free and isn't trying to compress anything solid, like a mouse nest. Then either pull the distributor and use one of those pre-oilers on your drill to bring up oil pressure or crank it with the coil wire off til you get oil pressure. Make sure you have fresh gas to the carb, plug in the coil wire and light her off. Have a fire estinguisher close by just in case and watch for stuck floats ect.
Good luck,
Tom
Good luck,
Tom
