brumbach
My 65 vette has a 1968 327-ci block. The heads and intake are correct. It also has a holley 4160 (list 3367) four barrel. The breather and oil fill tube are correct for 65. The valve covers are chrome aftermarket with a pcv valve on the passenger side and an air breather on the driver’s side to complete the pcv setup.
I intend to install the 7 fin aluminum covers to give the engine a more authentic look. Because the block is 68, the orifice next to the firewall that is supposed to be used for filtered fresh air intake to the block is nonexistent. During an earlier forum discussion, many remedies were suggested to support my intentions but the one that seemed to be the simplest was to cut a hole in the correct valve cover in an inconspicuous place (backside near firewall) and connect a hose from it to the air breather. Discussions did not cover the pcv connection or valve.
I’m ready to order parts to perform the task but have additional questions.
Most generic diagrams I’ve seen for pcv show the setup to run from “front to rear” of block (oil tube to right of distributor) or from “side to side” (valve cover to valve cover). To gain the near correct appearance of my engine, my setup will go from the oil tube (output) to the valve cover rear (input). Will this make any difference?
I plan to replace the 65-oil fill tube with a 67 tube w/ pcv valve installed. Even though the tube will be wrong, it is very similar in appearance. I’d use the existing tube but don’t know of a way to introduce the pcv valve other than possibly an in-line aftermarket valve. My holley doesn’t appear to have a threaded port to accommodate the 65-check valve. Do you agree with my approach?
I welcome your advice. Thanks in advance.
Bill
Bill
