- Couple of newbie shifter questions (4 speed Muncie trans)
I have an aftermarket Mr. Gasket shifter (hurst lookalike) in my car (bought that way).
I don't know how old it is, but it is really bad, and I'd like to go back to the stock look.
I've seen several new/original 66 shifter assemblies for about $220.
My question is I think I'll need that assembly and a original mounting plate.
I assume my stock shifter rods will work fine, hooking back up to the stock shifter.
It looks like the stock reverse switch isn't present in there (reverse lights don't work), so I'll need one of those as well.
Does this sound correct?
Second, it looks like someone cut through the fiberglass on the trans tunnel, driver side of the shifter (There is a small cover there held in by 4 screws). Was this hole originally there, or did someone really cut it out?
Third, when the car was together and driveable, sometimes the shifter would be in neutral position when driving, but actually in a gear (felt like 3rd).
I could use the clutch and everything worked, but I could not move the shifter. I could "gently" beat on the shifter rod, then drive a short distance, then come to a stop and I could then move the shifter back around easily.
This certainly seems like something is wrong in the trans to me, but I'm praying it's just the shifter.
Any ideas on that one?
Thank you again!
Doug
Thank you again!
Doug
