bobmanx
- Joined
- Dec 29, 2002
- Messages
- 169
- Location
- Southern Calif.
- Corvette
- 1967 White Convert. 327/350hp, 4 spd, with A/C
What are the pros / cons of using or not using a fan clutch on a 1967 Corvette Convertible? The car has a 327/350 hp. with A/C, 4 spd, and has a "spacer" where the fan clutch should be installed. The car was from Southern Arizona and when we shipped the car to Southern California we found some parts in the garage but no fan clutch there.
Now that I'm going through things and replacing old hoses, collant, and liquids etc, I was wondering if there is any benefits of running a fan clutch or not. I understand that a fan clutch will save a few horses by not having to turn the fan at speed, but what are the "small block owners" opinions. I would like to hear from those that have had their C2's for a while and how their cooling system is functioning with or without the fan clutch. I have no problem installing one on the car if the consensus is that it helps keep the cooling system within reasonable temps, but if there is a plus side to the "spacer", and the cars run cooler without it I can wait, and use the money to get some pieces that are needed now.
OK guys here's your chance, whats the opinions out there from those that are running today. Cooler/not cooler/noisy/what and where?
Thanks for the help, Bob
