jkern
I just replaced the alternator, regulator, and starter motor. Wires are all on the correct terminals. I think I have a short somewhere. May or may not be related to the charging system. When I turn the key to 'acc', with no load, the ammeter reads -20A. If I turn on a load (like the lights) in that position, the ammeter reads -40A or more. If I turn the key to the 'on' position (no load), the ammeter reads -40A. The horn works with the key in the 'off' position. I think the relay is OK. To start the car I need a boost from a battery charger. It pins (-40A) the ammeter in start and then reads about +40A after starting and very slowly drops off to +5A as the engine runs. The engine is running very smooth. No smoke anywhere. I switched out the coil but no change. I charged the battery out of the car. Seems to take a full charge without indication of an internal short. It was reading about 14V after charge. Drops to about 12.3-13V as the engine runs. I have tried another alternator. No change. Pulled all the fuses. No change. All electrical loads seem to be working without problem. From the schematic that I have, it looks like the only components in the charging circuit are the battery, solenoid, ammeter, horn relay, ignition switch, voltage regulator and alternator + the harness. I might have a problem in the ignition harness. Could the ballast resistor be the cause of this problem? Has anyone seen this problem before?
