'67 fuse box
R
REVN67
Does anyone have a detail of the fuse box with an indication of the proper fuses and exactly which circuits are protected by each?
The vehicle I just bought has a few improper fuses and at least one short circuit I'm trying to fix.
Thanks.
Noticed you live in the Boston area. Give Ron a calll at the Corvette Connection, 781.596.2800, he can definately help you. He is replacing the main dash harness in my 63 SWC, which has been cut up too many time. Definately recommend him for any work you may need, very reasonable and does good work. They recently moved from Lynn to Middleton, MA.
The fusebox (above left of the driver's feet on the firewall) should be marked.
Backup light and gauges... 10 amp fuse
Heater & air cond ... 25amp fuse
Radio & Wipers ... 20amp fuse
Instrument lamps ... 4amp fuse
Stop & Tail lights ... 20amp fuse
Clock, lighter, courtesy lamps, flasher ... 20amp fuse
AC high blower speed ... 30amp fuse
Headlights ... 15amp circuit breaker
Headlight motors & power windows ... 40amp circuit breaker
