c4c5specialist
Technical Advisor
Hi there,
Looking for the ACCURATE jet number for the main circuit on the center carb.
I have 66s on this one for both sides and I get massive spark knock and AF ratio is very lean.
Carbs are completely clean and correctly set per service manual guidelines. Ignition timing is correct both static, vacuum and mechanical advance.
Intake manifold gaskets are being done at the same time.
Allthebest, c4c5
Allthebest, c4c5
