Ok Allen, this is what the service manual says. "The position of the door is adjusted by sliding the door fore and aft to the limit of the slotted holes in the hinge pillar; in and out adjustment is done by installation and removal of shims located between hinge pillar and front straps of hinges; up and down position is determined by adjustment of rear hinge straps in slots of inner door panel. To adjust door, proceed as follows: 1.remove door trim panel 2.remove striker bolt after first scribing line on lock pillar surface following circular flange. This enables proper installation position. 3.For up and down adjustment, remove hinge cover(2 screws) for access to upper hinge retaining screws. 4.For in and out, and fore and aft adjustment, it is necessary to first remove instrument panel(left door only), right dash pad(right door), cowl kick panel, air inlet duct, and radio speaker, in order to gain access to hinge retaining screws. 5.Adjust door as required.(do not allow doors to hang on one hinge without proper support.) 6. Install previously removed striker assembly, trim pads, and panels and lubricate door hinges with lubriplate or equivalent. NOTE:after performing any door adjustment, the window and lock pillar should be checked for alignment and adjusted as necessary. Do Not slam door after adjustment without first checking the door lock and striker engagement. An adjustment may be necessary.
