roylindblad
I've spent hours searching this and other Corvette forums and haven't seen this yet. 1971 Coupe 100,000 miles 270 HP 4-speed 3.36 ratio. The car ran fine, I baby it I've owned it since 1975. All of a sudden with no noise or telltale warning sign, The rear end started binding up to the extent the car is not drivable. I can go 25 feet forward and some kind of friction stops the car. If I "push" it a little there is a big snap and it willgo another foot. Then I can back up about 20-25 feet and the same thing happens in reverse. The noise seems to be from the RR wheel. I had the car towed to my house. I proceeded to raise the car on jackstands under the shock mounts to keep the halfshafts level and the wheels spin freely in forward and reverse. I grab the wheels and check for play and there is minimal play on either side. The u-joints seem to be ok. I replaced a leaking caliper, dropped the car back down and it did the same thing. It seems that when there is weight on the wheels this puts compression on the driveshafts and this results in the "binding". Could this be a RWB or do I have big problems with the differential. The snap could be the posi locking but I had that problem years ago and GM posi additive fixed that. I thought it was the parking brake that had disintegrated (original) but that seemed fine. Any help would be appreciated. I have always been a do it yourselfer but this has me stumped. Thanx for any comments.
