captras
The tach on my 75 is stuck at about 1000 RPM, ignition off. When the ignition is turned on, it jumps up to about 2000 RPM and stays there, regardless of actual engine RPM, then drops back to 1000 RPM when ignition is turned back off. I have read about replacing the ICB, but have not been able to determine if these symptons are ICB related. Also, how much work is it to replace the ICB, if that is the problem.
Thanks in advance.
Thanks in advance.
